SUPERMAGOO
It would be great to show us some audio drums through this terrible monster child!
6bj6 you use for this audio amp?
why use EL34?
why use EL34?
tomelectro said:I just had a similar problem with a 670 clone that someone brought me to fix. When in moderate to heavy gain reduction, the left side-chain amp would launch into oscillation around 60kHz, which would cause the channel to over-compress, and also cause the right channel to go into gain reduction, even with no signal present on the right. This clone used a printed circuit board for the side-chain amp, and I think it was a layout issue, especially since it happened predominately on the Left channel, and the component layout was completely different between left and right channels. After spending much time playing around with the layout, grounding etc, I finally just threw in the towel and changed the 20pF feedback caps (from plate to grid of the last stage of the side-chain amp) to 47pF, which cleaned it right up. (If my calculations are correct, the 20pF caps were providing a rolloff around 120kHz, the 47pF bringing it down to under 60k).
So if you have a scope, try taking a look at your sidechain signal and see if there's any extra junk floating around on it.
SUPERMAGOO said:wow.
you are the genius who created the Poorman!
maybe you could help me.
I calculated the controlamp winding transformer.
See if it is correct. the ratio used is: 10:4:9,5
Core: 18.9 cm2 ordinary silicon steel.
primary turns: 2000
secondary turns (12bh7 feedback): 88.
secondary turns 2 (control amp out): 490.
Minimum Frequency: 32hz.
That's fine.
another thing is that I have doubts about the working conditions of 2c51. in my last version I used 5 tubes.
I have achieved a good performance with my ears but I suppose that understanding the conditions of work can lead to better performance.
in my next audio amp that I am undecided .... Select Valve 6ba6*10, 6bj6*10 or again 2c51*5?
another question ... in your power supply are using 6au6 instead of 6084?
(remember to have patience I'm a disaster with the English).
greetings.
I used 6BJ6 with screen and suppressor grid tied to plate. The old tube tektronix scopes uses the 6AU6 as error amp I did it and it works great.
tomelectro said:Yeah, that looks like a copy of an original. There was a nice clean high-res jpg that used to be around (posted by CJ?) . I don't have a place to post it, but if you want to PM me with your email, I'll pass it along.
strangeandbouncy said:Hi Supermagoo,
Thank you very much for this post. You have stirred me into action, and inspired me to have a go myself! Which edcor transformers did you use for in and out of signal amp? Also, how are you doing Gain reduction Metering? it is not on your schematic.
I am going to try to do this with a solidstate sidechain. Mainly to try save money, and a huge complicated powersupply!
you child sounds amazing on youtube by the way!
Kindest regards,
ANdyP
strangeandbouncy said:Dear SuperMagoo,
Thank you very much! Why 5 x 2c51 by the way? When you possibly have some time, I am very interested to see how you made metering work, if possible.
Many thanks,
ANdyP
