user 37518
Matador said:In fact, IEEE has been saturated with papers coming out of China showing that over the last 5 years, they've driven down the LCOE (Levelized cost of energy, which includes installation and future maintenence) by over 60% just due to scaling up production (subsidized, of course). I can't see nuclear keeping pace with that trajectory, regardless of the size of the reactors.
I mentioned the department of energy of the US, not a valid source for you? fair enough, I did a quick google survey, there is a lot of information on SMR and they all seem to concur, however I am guilty of not being thorough enough, I will grant you that, if I had to do that with everything I read that would be a fulltime job. First you asked for a primary source to back up my arguments, then you 'rephrased' by saying that you want non speculative, backedup (basically peer reviewed) sources, and used it as an excuse to prove your point, that is very different, and BTW what exactly is your point? do you seriously expect me to go to high impact peer reviewed nuclear science journals, read the literature and report back? this is the Brewery, I am not doing a dissertation to convince you, this is not a final doctoral examination.
Either way, i fail to see what you are trying to achieve or your contribution to the thread, are you pro/against SMR's? what is your objection to SMR's? on what do you base it? what do you propose? Are you talking about the green earth thing? climate change? what? I seriously don't know, so long it just seems that all you want is to win an argument and feel good with yourself when you said "it appears I have my answer", whatever that answer is. Fine, if you have your answer and you don't have anything important to contribute, then why are you still arguing? Do you want to engage in a debate? what? I don't know.
I did say science, scientists and predictions are usually wrong, but you are taking me out of context, you are cherry picking just like the press does when they 'ommit' certain parts of an interview, why not place the paragraph I wrote before that phrase? give it some context, I was addressing Kelvin's statement that the world will run out of oxigen in 400 years, which is wrong, I was refering it as an analogy that predicting 50 or 100 years into the future of climate change might be wrong, climate is not even an exact science per se. That is completely different from the SMRs, SMRs are not a theory or an abstraction like a physics particle that hasn't been found, some are operating today, https://en.wikipedia.org/wiki/Small_modular_reactor I know you might not be fond of Wikipedia but at the end there is a list of some current reactors, which are either operating, designed, conceptualized, under construction or licencing, that is very, very different from making a prediction 100 or 400 years into the future, which was my point, and now you just seem to be looking for things I've said to support your point, whatever that might be.
