Decided to change course and use the paint they had their home's exterior trim done in. Color is a perfect match for the vinyl fence....
Really didn't feel good about putting the extra money into products that had mixed reviews, I'm inexperienced with and didn't have time to waste.
The paint is actually really nice, top tier of Sherwin Williams...Emerald line.... it's zinc fortified with all the anti microbial stuff to combat corrosion and stuff. It's pretty hard stuff when dry plus, touch ups will be a lot easier down the road.... I've worked with plenty of acrylics and they can be very strong and very long lasting if done right. This stuff is actually self priming on bare aluminum...not sure how.... Didn't want to chance that though.
Got the inserts pretty cleaned up..Hit with some 150 to make things nicer...Applied self etching to all of it...not zinc chromate though....
...Sprayed a couple of coats and had water starting to leach out from a couple of the joints.... yuck... Had to deal with that..., sealed the joints with some eurethane modified caulk...sprayed a couple of more coats... I think it'll be fine. The time and money isn't there to worry about it but, I feel pretty good ..... The original finish didn't last but not even 7 months..... This should be an easy 7 years.... but mother nature may be snickering...
Paint was super thick and I didn't want to mess with thinning ...Had to use a big tip and it turned out like a rock finish almost... Kinda cool.. Not normally what you'd want but most of their outdoor furniture has same texture...Maybe powder coat....
We'll see. Lot of coating on them now....Got some 316 bolts for everything... $75 just in those.... probably going to put some neoprene washers under them just to give a little extra for water to deal with....
Thanks so much for all the info. Fascinating stuff and I was actually able to relay info to the guy that made these inserts so he doesn't do that again..
