I managed to persuade LTspice to plot a series of graphs for the bass boost/cut. The attached pic shows 2dB steps and I added one further plot with the lower resistor set to zero so you can see the hi pass filter effect this EQ can produce.
Looking at the boost, the mid point seems to be around 200Hz. The cut frequency mid point looks like be about 80Hz . The bottom yellow trace is the HPF position. This has a -3dB point at about 110Hz.
