I just did a quick sim and the R is half what I said because it is the parallel combination of the the 10K and the 11K from the centred treble control. Bottom line is 2H give a 3dB point of about 300 Hz and the ultimate shelf is at 100Hz. I think the 0.22uF of the original must be wrong because it gives a shelf at 1KHz. If you use 22nF you get a shelf at 10KHz as expected.
I have attached the LTspice sim file so you can play with it yourself. You will need to change the extension to .asc to be able to load it into LTspice.
