CurtZHP
I'm in the process of preparing for some major changes in my home studio. Most notably, I'm kicking around unloading my digital console and associated interface (which are starting to show their age), and downsizing to a more streamlined setup. I just don't do the kind of work I used to, and this stuff is mostly overkill. Pretty much all my mixing and processing takes place "in the box" now, so the mixer has become nothing more than a glorified router and monitor control. That's a lot of bells and whistles for what could be accomplished with a knob and a couple switches.
While I'm shopping around for what I will ultimately replace it with, I'm experimenting with a few options.
One is in the form of an eight channel sound card I inherited from the radio station where I work. Eight analog and/or digital ins/outs, but no monitor control. So, I'd have to build/buy one. I was tinkering around with this design....
http://www.audiotechnology.com.au/wp/index.php/on-the-bench-diy-monitor-controller/
Is this a truly balanced signal path, or should I do something different to achieve that? I was also thinking of something similar involving a good ol' Alps RK27 quad pot, putting each stage on both + and - of each channel, but they're not very easy to come by. And would that even be an improvement worth that much extra cost? Basically, I'm coming out of balanced outputs 1 and 2 of the sound card (using other outputs to feed the occasional headphone amp), and going into the balanced inputs of an amplifier.
Didn't want to shell out a lot of money, because I'd rather put that toward what I ultimately end up with. But then, if this works out as far as workflow is concerned, I could see putting the funds into improvements on this setup.
