moamps said:The additional source of mistracking in this type of attenuator (balanced L-pad) can be also the total resistance tolerance of pot's gangs which is +/-20% for Alps and TKD.
I strongly suggest using a 24 or (better) 32 position switch based attenuator here.
The TKD are much much better than 20%. Have you ever tested one? Every one I have has been less than 0.2dB difference between channels for the whole throw.
