Ive done a set of fostex pm03's and a converted Kef 102ab with a subwoofer panel for bass, I run a 35 w pc Canford audio amp for the mids ,-12db at 50 hz, and 2 x 1.5w El84 based amp on tweeters . The I split the x overs into hi and low pass and pulled some of the ultra lows .sub 200hz by making the coupling cap to the tweeter amp small . Of course this system doesnt go loud and at a certain point the tube tweeter amps gracefully distort . at normal domestic listening levels it all works very nicely indeed . I'm in the middle of constructing the same type set up ,passive and active combination as before but this time Im throwing some 2-3 kg of copper in the crossovers all air cored , and massive cable , if heat is the enemy of passive crossover maybe all the copper will act like a large heat sink and wick away heat when its produced in the voice coils, caps and inductors . The benefits of dsp cant be argued against especially in big multiway pa systems ,
I just want a simple all analog system, I can afford to take the time to tune the crossovers in conjunction with REW and appart from the active crossing over of the lows its just poweramp caps and coils , no switchmodes , no class d, no op amps ,and a tiny component count. I dont listen loud anymore so its really all about the first few watts ,I'll try avoiding any kind of speaker protection apart from relays to control turn on transients which are already built into the Hafler XL-600 , and just allow the poweramps massive reserves to cope with the odd transient or opperator induced thumps/noises that happen from time to time.
The benefits of dsp cant be argued against especially in big multiway pa systems ,I have my current active monitors 20 years at this stage and I'm not prepared to spend my money on any of the modern offerings with , dsp and class d under the hood .Neumann KH120ag is astonishingly good but I couldnt splash that kind of cash .
