Probably because you haven't seen as much bad design than me.squarewave said:It's difficult to think of a scenario were it would have a negative effect.
Wrong ASSumption.Abbey road d enfer's example (which I assume is trying to demonstrate some kind of loop that might have currents induced around it)
[/quote] is not particularly realistic since all of the ground leads would stitch together the two planes [/quote] Have I mentioned two planes? I've just shown an example of how a copper pour actually connects points that souldn't be.
No loop involved. Think resistance and current circulation.and break up the loop making it (them) insignificant.
Really? How do you know that?And the drawing is not representative of how the parts would be laid out.
Again, I haven't mentioned dual copper pours. The problem I hint exists in single-sided layouts.It would have to be all surface mount spread out over a large area with no vias.
But there is! Current in the rectifiers and associated smoothing caps is a major source of pollution introduced in the audio reference ("ground").And something would have to be throwing some serious current around.
Who said it is deliberate? AFAIK, autorouters don't have the intelligence to organize ground circulation hierarchically when all "grounds" are labelled identically. An autorouter would gladly connect the xfmr center tap to an input ground if it "thinks" it's convenient.I think it would challenging to deliberately design a board that exhibited negative effects from a ground plane loop like that.
