Phantom power blocker for synth outputs
Being strictly a location engineer with no studio experience, why aren't alll studios wired with XLRs for mic in, and TRS for line in?
Being strictly a location engineer with no sudio experience, why aren't alll studios wired with XLRs for mic in, and TRS for line in?
Studios are not wired with XLRs or TRS. Studios are all wired to a Patchbay.
The most common patchbay used is with Bantam connectors. (there's others)
Any input or any output will have the same connector, which is very practical an convenient.
But someone that is not experienced might connect for example a Compressor output into a Mic Input that has the phantom power On.
________________________________________________________________________________________________________________
As for professional hardware units/equipment, the units itself
Mic In and Mic Outs are normally XLR
Balanced Line In and Balanced Line Out can be XLR or Jack TRS, depends on the manufacturer choice.
XLR has a locking mechanism so it's normally preferred in Professional situations to Jack TRS
OP stated: "straight to the console (through an XLR patch panel)."; not a patchbay.
Hence my question why would anyone build a patch panel that used XLR for mic and line, rather than TRS for line, to easily avoid this phantom poweer issue?
In a few studio builds, I specified that the mic lines from the wall panels in the tracking space(s) terminate in a panel in the control room which had male XLRs for the incoming signals. The same panel also had female XLRs for connection to the mic preamp inputs. Short male-female XLR cables did the patching.
The reasoning was that the bantam patchbays used for the line level patching weren't really reliable for the mic levels. For instruments. we used DI's.
Bri
    1 MB
Because a lot of pro outboard is line level and uses XLRs. You idea will certainly work but you would need a lot of XLR to TRS adaptors and sooner or later someone is going to plug the XLR end of one into an input with phantom power on it.
OP, are you sure your synth does not have capacitor coupled outputs?
I see no reason to DC couple a low level output, unless you want 0.001Hz bass response.
Adding output coupling caps shouldn't be too hard, cut a wire or a trace put in a leaded cap or an SMT cap, if some bonehead forgot to include it.
Mic inputs are special, they are not "line" level.
Even if the outputs are capacitor coupled, one would need to be sure that the caps are rated for 63v, which isn't gauranteed on much of the gear I have looked at over the years....
Even if the oututs are capacitor coupled, one would need to be sure that the caps are rated for 63v, which isn't gauranteed on much of the gear I have looked at over the years....
I’ve not checked. Two that I’m most immediately worried about are a Juno 106 and an ensoniq esq-1 if any one knows about the output sections on these.
If they have capacitor coupled ouputs with caps rated at or above 63v they should be safe correct?
What do you mean by “I see no reason to DC couple a low level output, unless you want 0.001Hz bass response.” ?
Bri
This is exactly how I’ve always done it as well.
This setup is my personal one and I have basically zero budget haha.. I just had a few tt patchbays laying around so I made due.
0.001Hz bass response:
What is the lowest frequency of the output you intend to generate?
Is 20Hz low enough? What is the load impedance of the input?
https://www.digikey.com/en/resource...sion-calculator-low-pass-and-high-pass-filter
Use a "big" enough cap to pass the lowest freq of interest, given the load impedance and size constraints. Use at least the voltage of the phantom, 50V or 63V.
With a 6.8k load and a 10uF cap the -3dB roll-off is at 2.3Hz.
Maybe UVP1J220MPD ? 22uF 63V Bi-polar
I just checked the M1516 schematic. It has a pair of switchable mic inputs which are fed phantom power. There is a +4dBu input position on the mic gain switch which bypasses the mic pre but for some unknown reason it does not disable the phantom power. Even in the +4 position, the input impedance is only 1K3 which could be problematic for some synth output. I think you definitely need some form of protection such as that proposed by Bill.
I agree! Unfortunately, I have also come across many cases where there was phantom power at the input of the line. Otherwise, it is worth turning it off, even for dynamic microphones, because it can produce significant dielectric noise in the cables (when they are moved or stepped on). (I used to be a sound engineer for rock bands.)
The output is probably an (electrolytic) capacitor in most cases, but the +48 volts is higher than the output circuit voltage, so it will be reverse polarized and the output amplifier stages may fail. A long time ago, I put a 10:1 matching transformer on the output of my friend's synthesizer, so the 47 kOhm unbalanced output became a 470 Ohm balanced output. The sound has also become much better. Of course, this is the most expensive, but the best sounding method.
