strangeandbouncy said:
still, will 1n4007 do, or is there a reason for 1n5007 . .
My mistake, that should be 1N5407 which you can get from Farnell etc.
In fact the 1N4007 would probably be just fine. The load current is only a few mA so you would have thought a 1A diode would be fine. However, with a capacitor input filter there is a large surge current at turn on as the capacitor initially charges up. How big this is depends on the value of the capacitor, its ESR and the transformer secondary resistance. Now, in mic pres power supplies, I often use 470uF caps and if the transformer secondary resistance plus the ESR of the cap is only 10 ohms then you get a 20A surge current!
Because of this I tend to
over specify rectifier diodes in such power supplies so that I have now more or less standardised on the 1N5407. However, looking at the spec of a 1N4007 I see it can take a peak surge current of 30A so it should be fine from that point of view especially as there is no need to use a cap as large as 470uF.
The other thing you have to watch with using large caps is that once the supply is up and running, the diode only conducts for a short time each cycle and and the current through it is many times the load current. Again, with a 470uF smoothing cap and the same assumptions for ESR and transformer series resistance and a load of just 5mA, this peak current is just under 150mA so again it should be well within the capabilities of the 1N4007.
So, on balance, the short answer to your question is yes, the 1N4007 will be fine in this application!
