@Tim
For a line level mixer this is an excellent approach. Additional screening around the tubes themselves is always a good idea. Signal cables should always be shielded as well but ground connections should not need it. Make sure all the sign writer's aluminium sheeting is electrically connected together and that there is a single connection from it to analog 0V (HT -ve) right where the power inlet socket is located.
47K bus feed resistors are fine in all cases. Make sure the LCR switch grounds any unused 47K to minimise crosstalk. If you use 100K pots for FX sends you can use LOG or LIN parts. LOG pots will typically give you 20dB down at 50% rotation. To make them more like slider faders which are normally 10dB down at 50% travel you can use a LIN pot. The 47K bus resistor then acts also as a slugging resistor to give 10dB down at 50% rotation.
The only thing I am not sure about are the input transformers you have chosen. Which mixer did you pull them from. Could be useful to see a schematic of how they were used originally.
All in all an excellent project.
