Hey rock soderstrom,
The behavior of that acid mix is generally pretty predictable, and it can etch rather fast with its own heat, though I did have one occasion early on, which I believe was with aluminum, where it went nuts when the metal went in, and started foaming and bubbling violently. I had to quickly jump away from it until it calmed down. Fortunately, it was sitting on a big plastic outdoor trash bin. I'm thinking maybe it was the heat outdoors, but I believe the acid does age in some way, so it may have been a brand new jug. I could usually add a bit of one of the ingredients, or maybe a pinch of salt, if it had gotten too weak. Just make sure to do a small test piece (outdoors) in a nice open spot with the usual emergency junk (goggles,gloves,baking soda,water). The totally invisible fumes from that acid will knock you on your tail if you get anywhere near them, so be careful there as well. I'm not positive, but I think it may even have rusted some things in my shop which were near the closed jug, so I now keep it outside and far from any metals.
I started with ferric chloride, moved to sodium persulfate crystals, then ended on the muriatic mix. It seems to do all of the metals I've needed it for, and is obviously quite cheap. They made me buy way too much of it at the home improvement place here, and it still barely cost anything. I also had made a really nice tall, flat etch tank with a heater and bubblers back in my sodium persulfate days and don't even bother with it now.
I'll keep that Samsung in mind if I give up on this Brother one. I think I remember people even having good results with certain brands only when they
did use cheap third party toner carts, so I guess as you said, it's a matter of finding the right combo and sticking with it (and hoping nobody changes suppliers or formulations).
Let me know if you ever try that plastic or anything else. I've been too lazy to do it again. I'd also be interested in the color toner thing, but with as much of a crapshoot as the black seems to be, I'm not sure I'd even take a chance on buying a color laser unless I knew for certain that I was getting the same model and toner someone else was using. That green TRF foil worked really well with the previous HP printer, but it doesn't even pretend to stick to the Brother stuff. I also had white back then, but never got that to stick.
This attached image shows the drill hole punch marks I was talking about. The etching to me is worth it for that alone. I still haven't gotten my metal skills down to where I get 100% on-target holes without those. I also kind of like that rustic look you get from the texture in larger etched spaces when I've done inverted un-etched labels surrounded by black, like in that "test test" thing in the center of the other picture.
Take Care
