Proel Flash 15 SA - Active Subwoofer Schematics Need
r2d2
A-rea 51
Hello
need schematics for Proel Flash 15 SA - Active Subwoofer
have troubles with the amplifier (with crossover)
after a first fast check not found parts or tracks burned
for proceed  need to get schematic
any help is wellcome !
thanks from now
peace
r2d2
Hello,
were you ever able to get this service manual?
I have a Proel Flash 12A that I need to repair, tried to contacting Proel for the service manual or schematics but it was a dead end and can't find service docs anywhere
thanks
There could be one on Electro Tanya:
https://elektrotanya.com/proel_smart_12a_am160_am161_am321_am320_am320s_sm.zip/download.html
I always search first in Electro Tanya, great website by the way.
Those are for the "Smart" model and I was looking for the "Flash",
2 different units.
Anyway, I contacted Proel again yesterday, and today they sent me the schematics over email.
what a great service I couldn't be happier.
A big applause for all the companies that release schematics so that they're units can be repaired.
I’m sorry for that,
I was much more lucky then as they replied to my message by e-mail with the schematic attached
if you want I can send you by pm the email address they used to send me the schematic
Hello
thanks from now
peace
r2d2
hi, please, i hope you have this schematic. i have a problem width any transistor. you can help me, and, you can give me that scematics. thank . Davide from Italy
Hi ,
thanks for post,
unfortunately still not found thats schemes about the subwoofer 15SA,
the subwoofer issue was caused by a quite big resistor vertically mounted,
too near an electro cap body ( so bad design ? )
that above a certain volume due to vibrations generated by the woofer
the resistor metal pin uncovered went to touch the body of that adjacent electro cap
making a short that burn the protection fuse (fortunately)
without damage other parts,
bent a bit the resistor moving it away a couple of mm from the electro cap
and covered the metal pin with insulating sheath
the subwoofer has not given any more problems
and it is still in use,
if not already checked,
maybe it could help,
"whoops" has kindly posted a doc here
https://groupdiy.com/index.php?topic=76181.0
cheers.
