Have the PRR176 boards and most of the components (including several sets of tubes), but I don't have the latest REV. And that's why I never sat down to actually build it. Any version prior to REV4 always read on this forum like being a PITA to build, as there seem to be various issues with the REVs like missing traces, component placement, noise, poor schematics, God-knows-what else (probably due too much excitement paired with lack of quality control at the time of shooting out those boards too quickly). So until this very day, I don't know how different it really sounds from PRR's take.
Built the original PRR VariMu. As 'living sounds' said, it was meant to use cheap and even leftover parts we all usually find in our drawers. No frills, proof of concept kind of thing, just basically functioning. The most expensive parts are the four(six) Xfmrs, two(four) tubes, and the PSU, oh and the case. -- I fully enjoyed building it because I (mis-)used it as a learning platform. Reading any Vari-Mu schematic I could get hold of, as well as IC based stuff for the sidechain etc etc, mine was a cable salad bowl for almost a decade -- always in use, but half of the time on the bench, in a state of being changed, or having things added, or things being auditioned just to be dismissed. Now finally finished, the majority of components are off-board or on daughter boards etc. -- If you intend to go down that road, better start with a huge case. I started small and inside is tight as a rat's earhole.
Also, the biggest trouble I had with the PRR VM unit was that it was always in different states of being somewhat noisy, which gave me a lot of headache. So I read a lot and ended up trying many different things, before finally the unit quieted down sufficiently. It has to do with mixed grounds and the unit being single-ended (internally unbalanced), I think. -- Either way, the PRR PSU works (over here now) but it's not great. So my advice, if you plan on building the unit, is to separate your grounds and best ditch the PRR PSU entirely and maybe go straight for the PRR176 REV4 PSU.
