buschfsu said:also prr doesn't mention a transformer, i assume the cathode follower takes care of the impedance so to balance i just need 600:600 edcor iron?
The threshold control seemed to only allow a very small selection of gain reduction. I'm currently using a 100klog and this gives a much wider selection of gain reduction. The heavy reduction will only work for 'effect' compression but I dig that.
Matthew Jacobs said:... voltages on all the pins of my 5532 and TL074.
I've checked my solder traces, joints and component placement.
MagnetoSound said:What sort of voltages?Matthew Jacobs said:... voltages on all the pins of my 5532 and TL074.
Sounds like you may have overlooked a ground connection, unless your chips are blown.
Balanced supply means you should have no significant voltages on the 5532 other than the power rails, and only the 1.5v bias wrt ground on the 074.
