How many of you have actually used half of the split primary as a high-voltage coil? I've done it once, in a tube mike power supply that required very little current. I would be curious to hear anecdotes about the practical limitations of current output, both from the low-voltage and high-voltage taps, relative to the nominal rating of the transformer. I would probably not even try it for any kind of power amp. I also wonder what the transformer manufacturer would have to say about it.
