gridcurrent
- Joined
- Aug 28, 2009
- Messages
- 589
abbey road d enfer said:@aazaal and Winston,
I'm sorry you misunderstood my comment for denigration.
As I already wrote, the OP was a description of a design without any explanation as to why and what goal was pursued.
Members who have not achieved your level of understanding needed an explanation.
Winston, you provided it.
As always, language barrier and internet not carrying intention.Winston O'Boogie said:Ah, then it may actually be ME who should say sorry my friend. I understood completely that you wanted others to understand the goals or intentions. I never in a gazillion years thought that you needed clarification. Doh![]()
I addressed you merely as a stepping off point from your questions, which were good and valid. Probably should've been clearer in that
As I said, "I know you know" and lots more besides that I forgot to cover.
EmRR said:I believe way back in time analag had posted some PP designs with output coupling more rarely seen, like dual parafeed with the output primary floating, maybe some other things too.
Winston O'Boogie said:As a potential part for push-pull, choke-fed, parallel feed with floating output transformer, the UT26 from AMI looks good for not crazy money. 1280H end to end.
I wonder what the maximum output is as an output transformer too when push-pull fed, and from lower than 30K source. No doubt it'd beat the +10dBu for 1% distortion spec that's listed, but by how much?
http://www.tab-funkenwerk.org/product/ut26/
To know that Winston, the only solution I see is to buy one and take the time to try it out...Winston O'Boogie said:I wonder what the maximum output is as an output transformer too when push-pull fed, and from lower than 30K source. No doubt it'd beat the +10dBu for 1% distortion spec that's listed, but by how much?
aazaa said:To know that Winston, the only solution I see is to buy one and take the time to try it out...
Paul
Winston O'Boogie said:Hope your coffee break was good Aazaa, nice run through of the DC balancing![]()
