So I've made some progress!
I've built my own front panel as an additional sheet metal on the pre-made enclosure. A little paint, some waterslide decals and that's it! I'm not going cheap other enclosures - it's just that I like doing this part for myself. Did five other units this way and I like looking at it in my studio rack, knowing it's 100% DIY me!
I realize it was a mistake to try to calibrate this compressor in a shoebox. A big mistake! Most of the problems I had back then are gone now. When mounted into an enclosure, I did completely new wiring. I don't have problems with noise anymore. I can hear noise only when both in and out potentiometers are max cw. The noise is "healthy" meaning it doesn't contain 50hz or 100hz hum. I'm hoping to lower it even more with diy inductors on L1 position (thanks to Bruno2000).
Most of the time in past two weeks I've spent debugging my relay board that is supposed to switch stereo link signals between boards. I had to move the relay board with it's small psu to the other side of the enclosure to avoid HF buzz it injected into the output transformer. Thankfully I had enough free space inside to do it.
I'm not experiencing severe "thumps" on the attack anymore. Right channel has none at all, while left channel can sometimes thump when the signal is near the treshold. If input is high enough so it grabs a lot of audio, then this thump doesn't happen. It probably has to do with the fact that I was messing a lot with trimmers on the left channel before I put the board into the enclosure. I left all the trimmers (except voltage regulator) untouched on the right channel. I've tried to put left's trimmers to an original position, but I'm not sure if I did. I'll probably unsolder most of them, readjust them and return them back to the board.
Metering doesn't make sense, but it behaves exactly the same on both channels (that's after I put left channel trimmers to the original value). I like it how it moves. But makes no sense! hehe! I would need to measure the treshold and ratio curves before I can start tackling with meters. I plan to print my custom scale on those ebay meters I'm using, but to be able to do that I would need to know what's going on those signals. And funny fact is I totally dig the mA scale and I'm tempted to leave it as it is. But on the other hand it feels kinda ridiculous not to finish the damn meter!
Can anyone explain to me how to measure and plot the ratio of the unit?
I have an oscilloscope (usb cheap one, with two inputs) and PC audio card. I also have an access to a laptop with Smaart 7 software for measuring audio signals.
Still don't have any dedicated signal generator except PC's audio interface, so I'm limited to 20-20khz and not more than 2 Vac generated signal! But I guess signal generator from my PC won't be a problem.
So how do I do it?
Luka
