Biasrocks
mdainsd said:If you have decent skills you should be able to get these up and running.
If you love DIYing then you will continue to refine the tuning of these mainly through time with a scope and meter and a handful of transformers.
I'd prefer to have a base build with a bom that works, I'm not sure that's currently the case.
After that's accomplished, then certainly there's plenty of room for experimentation and improvement.
That has been the way I've done the majority of my DIY projects for the past number of years, from LA2A's to 33609's.
bruno2000 said:There are no flaws in the board, but some in the BOM. YMMV.
Bruno2000
Perhaps we could compile a list of changes / mods that are required in one place so that they are easily accessible.
I'll start.
bruno2000 said:Rob Flinn said:TIP : Make sure that you have the wiper connected on trimmer R44. Depending on the particular type of trimmer you use it may not be, due to a fault on the pcb layout. You may need to add a bridge between pad & wiper. This has been discussed before. If you do not have this connection you will get through quite a lot of 1n400x diodes in the psu part of the circuit because they burn up ....
IIRC this is true for ALL of the trimmers except the Voltage adjust.
Bruno2000
Mark
