I have the same meter problem that has been discussed in earlier posts. I meter 4db of gain reduction when no audio is being passed. Meter adjust makes small changes, but not enough to zero. Interestingly when I take the IC out of the circuit I meter 8db of gain reduction. Has anyone got any further thoughts on this issue?
I know some of you have been tweaking various trimmers and experimenting. Is anyone getting close to a definitive setup. I have everything set up and built to the sr1200 build guide.
mdainsd said:
Your question about the switches and which side of the board they mount to. Comparing the silkscreen on the Collective Cases enclosure with the image of the 3.14 PWB...the switches would need to be mounted on the backside of the PWB with the silkscreen, header and other components facing away from the front panel for everything to line up (control name wise).
But...everything should be verified with the schematic and an ohm meter.
This is wrong, to be fair It does say to check with an ohm meter and schematic. However I spent ages triple checking. To clarify for anyone about to build this, the components face the front panel and the Lorlin switches should be soldered on the same side as components and silk screen.
