[quote author="tardishead"]
should work fine, but is somewhat overkill. I'd save an output with that sort of level handling for a better suited project.
Like what? The transformer I have is for SE only - no centre tap.
[/quote]
something that can actually put out that sort of level. Lots of things. It's hard to find a SE transformer that will put out that sort of level; they are expensive, and wasted on the BA-2. Think more like BA-11A for that iron.
I have a few old output transformers - they all seem to handle round about 20dbm. I thought it would be better to overate the output transformer so that the valves distort on peaks and not the transformer saturating.
but that's a moving target; dependent on many things. and for transformers, remember rating is at lowest frequency. a +24dbm type with 30 Hz bottom rating will do closer to +34-35dbm at 100 Hz, increasing with frequency. So unless you are tracking pipe organs or whale voices, you needn't worry with +24 dbm at 30 Hz response. Many vintage tube pieces use a transformer that can be overloaded at the lowest frequencies about the same time the tube breaks up. And it is a part of 'the sound' we are trying to recreate.
What would the original transformer in RCA-2a etc be rated at???
the BA-2 is rated for an output level of -2 dbm, so you would be wasting a lot of expensive iron headroom using it in a BA-2. The original iron is rated for about +12dbm. UTC A-25 or similar.
I am a bit in the dark about "unbalanced DC". Surely there is more than 5ma DC going through the primary of the output transformer on the RCA bA2??
No, probably not. I'm going to guess 3-4 mA. And 5 mA will be rating for full low frequency response; lessening low end slightly past 5mA, melt down somewhere on (far, probably) down the line.
have a read here; I already forget why:
http://www.groupdiy.com/index.php?topic=21504&start=0
