Thank you so much for the great explanation JR
benb said:I think those leakage numbers are "real," the table says "typical" but they're probably much higher than what you would normally see.
1. it's from 1968, and electrolytics have steadily improved since then.
benb said:is this for the older ones you found that you want to reform?
2. The text above the tables says "...it is probable that these relate to a temperature of 70oC." That's way hotter than the "standard" room temperature of 25C (though it could be typical for a loaded PC switching supply or a not-well-ventilated device using vacuum tubes), and leakage should go down greatly with lower temperature.
If I saw a cap with that much leakage at room temperature, I'd lean toward throwing it out.
