Hello,
first of all thank you all for the guidance.
So I had fun today testing some of the capacitors
Some of the Philips capacitors have the tolerance written, some don't.
The ones that have the tolerance written say -10% to +50%, so I took that as a reference.
Not all of them were Philips, I had also BC, Eiko and ITT
MEASUREMENTS
_______________________________________________________________________________________________________________
VALUE: 4.7uf 63V PHILIPS (batch of 10)
Expected Tolerance: 4.23 to 7.05
Reference ESR: 2
Capacitance measurement FLUKE: from 8 to 9.8 (higher capacitance than tolerance)
Capacitance measurement CHINA: from 6.3 to 7.2 (most within tolerance but close to upper limit)
ESR measure: from 2 to 6.5 (most in the 4 region)
REPORT: Both Capacitance and ESR seem higher than they should. ESR much higher than reference
VALUE: 6.3uf 64V PHILIPS (batch of 10)
Expected Tolerance: 6.12 to 10.2
Reference ESR: 2
Capacitance measurement FLUKE: 7.78 to 15.6 (most in the 9 region within tolerance)
Capacitance measurement CHINA: 6.88 to 9.65
ESR measure: 2.85 to 4.4 (some caps keep increave ESR while measuring)
REPORT: Capacitance seems within tolerance but close to upper limit. ESR much higher than reference
VALUE: 10uf 40V EIKO Germany - BIPOLAR (batch of 10)
Expected Tolerance: 9 -15
Reference ESR: 1.7 - 2
Capacitance measurement FLUKE: 10.5 - 12 (within tolerance)
Capacitance measurement CHINA: 10.1 - 11.61 (within tolerance)
ESR measure: 0.15 - 0.29
REPORT: Capacitance Good. ESR much lower than reference, these are EIKO Bipolar caps could these ones be lower ESR capacitors?
VALUE: 15uf 40V PHILIPS (batch of 10)
Expected Tolerance: 13.5 - 22.5
Reference ESR: 1 - 2
Capacitance measurement FLUKE: 23 - 104 (most in the 25 region)
Capacitance measurement CHINA: 21.6 to 65.4 (most in the 22 region)
ESR measure: 0.45 - 1.83 (most of them measure 0.5 ESR)
REPORT: Capacitance higer than tolerance, one cap measured 104uf. ESR values lower than reference
VALUE: 22uf 40V PHILIPS (batch of 10)
Expected Tolerance: 19.8 - 33
Reference ESR: 0.8 - 1
Capacitance measurement FLUKE: 30.3 - 36.4 (higher than tolerance)
Capacitance measurement CHINA: 20.1 - 25.3 (within tolerance)
ESR measure: 1.45 - 3.69
REPORT: If China meter is right Capacitance within tolerance. ESR much higher than expected
VALUE: 100uf 25V PHILIPS (batch of 10)
Expected Tolerance: 90 - 150
Reference ESR: 1
Capacitance measurement FLUKE: 116 - 127
Capacitance measurement CHINA: 70.5 - 78
ESR measure: 0.92 to 2 (most ESR's measured 1.5)
REPORT: If Fluke 179 is right Capacitance within tolerance. ESR higher than expected
VALUE: 100uf 40V PHILIPS (batch of 10)
Reference ESR: 0.3 - 0.5
Capacitance measurement FLUKE: 130 - 152
Capacitance measurement CHINA: 85.5 - 106.6
ESR measure: 0.7 - 1.76
REPORT: Capacitance within tolerance. ESR higher than expected
VALUE: 1000uf 40V PHILIPS (batch of 10)
Expected Tolerance: 900 - 1500
Reference ESR: 0.04
Capacitance measurement FLUKE: 1077 - 1100
Capacitance measurement CHINA: 1037 - 1072
ESR measure: 0.04
REPORT: Capacitance and ESR all GOOD. Fluke and China measurements become closer
VALUE: 1500uf 25V PHILIPS (batch of 4)
Expected Tolerance: 1350 - 2250
Reference ESR: 0.05 - 0.1
Capacitance measurement FLUKE: 1495 - 1631
Capacitance measurement CHINA: 1496 - 1620
ESR measure: 0.07 - 0.08
REPORT: Capacitance and ESR all GOOD. Fluke and China measurements are the same
VALUE: 3300uf 25V PHILIPS (batch of 4)
Expected Tolerance: 2970 - 4950
Capacitance measurement FLUKE: 3095 - 3566
Capacitance measurement CHINA: 3110 - 3570
ESR measure: 0.04
VALUE: 4700uf 50V (batch of 4)
Expected Tolerance: 4230 - 7050
Reference ESR: 0.05
Capacitance measurement FLUKE: 4850 - 4890
Capacitance measurement CHINA: 4790 - 4800
ESR measure: 0.11
REPORT: Capacitance GOOD. ESR higher than espected
VALUE: 6800uf 35V ITT (batch of 3)
Expected Tolerance: 6120 - 10200
Reference ESR: 0.03 - 0.05
Capacitance measurement FLUKE: 7632 - 7874
Capacitance measurement CHINA: 7540 - 7790
ESR measure: 0.02 - 0.04
