Replacement Grill Mesh.
Help Support GroupDIY:
Tubetec
With something like a shure 58 I've often used an off cut of a drum stick , put the rounded back end inside the grill ,hold it at the top and strike it down on a hard surface , with a bit of luck you can tap out the dent and make it look a bit better . Condenser mics with much finer mesh require more carefull handling , you should be able to get some of the way with hand and finger presure , be more carefull if your trying to use blunt force though .
Without more details of which mic your tring to repair its hard to be precise about it.
TBP
Member
Thanks for the reply, The first mics are just a pair or Studio projects B1s .. These have been dented with drum sticks. given the damage on these more interested in replacement "mesh" then pushing the dents out ( already did that with limited success ).
Tubetec
Hi Kieran,
Inteligent use of blunt force .....
Funny how a drumstick was the original cause of the damage too.
Some mics have the mesh moulded into the headshell ,in some the mesh is replacable/removable and retained by screws.
Congrats on the Sufjan Stevens record , its getting a lot of plays on night time national radio here in Ireland .
TBP
Member
Hi Kieran,
Thanks, Sufjan is a real treasure of an artist. Hoping to find a vender for screens. Also a little guidance of how to measure the "thickness" of them. Something Like this but not mic specific.
Tubetec
Digital calipers might be a usefull way to measure wire diameter and mesh size , usually below 20 bucks/euros to buy , always a handy tool to have in any case .
mrgrooves666
Active member
I've bought and used mesh from ebay on many ocassions, plenty of suppliers there, different materials and mesh sizes can be found.
GeorgeToledo
Drum stick, wooden spoon, or pestle from the inside. But I have never needed to cut off the end.
You can get mesh from:
GeorgeToledo
Sometimes the fine grade stuff used inside for extra layers is literally the same stuff used for kitchen hand sifters/strainers, and you can just pop over to the nearest kitchen supply shop if you just need a little bit and can deal with working with the shape.
MicDaddy
Lincoln, Nebraska
If anyone finds a supplier in the USA that can process mesh into shapes let me know please. We need to make replacement grilles for the front head basket on the RE20, it's a 312 stainless at 16mesh if i recall.
What works with the RE20 for "reshaping" often is technique similar to the drumstick (I use back end of a screw driver) but also another big help for really misshapen grilles is a set of crude tooling making use of a plug/slug of aluminum in the "inside" shape of the basket and a delrin form, place headbasket into form and plug into headbasket and smack with ball-peen. Surprisingly works well (so long as you don't punch the seated grille out of the frame which does happen)
kato
Indianapolis, USA
Good tip. I've used brass mesh from McMaster for my janky brass pipe U47.
I wonder if I can try some wider mesh like #10 or #12 for a more open grille to emulate the Reference C mic in this body.
Here's what #12 steel looks like from an Amazon seller. CORRECTION: That's #5 mesh. Lower # = bigger gap. Might be too heavy and hard to form, eh?
kato
Indianapolis, USA
I might just take my chances with mesh #8. Seems plenty transparent. Coupled with some dampening foam on the bottom of the basket should give me mostly pure capsule.
kato
Indianapolis, USA
This was my cutout guide for a homemade U47 basket if anyone is interested. It was from years ago so the McMaster parts #'s might be different.
  • screens.pdf
12afael
Helsinki
I 3d printed a two part mould to repair this grill from a Beyer M260. It worked very well you can use clamps or a press if more pressure is needed. Completely diy possible.
