Hey mate. That's down in the noise, and it's not unusual to see harmonics at those levels high up in the spectrum that are due to interference from power supplies, internally or externally, for a connected device, nearby lighting, a connected device, even if that device isn't connected.
I used Lynx Auroras in a great commercial studio for years where I was also the tech, and they were great. I would often use analysers there and I never noticed any issue like that, that I can remember.
You probably don't have the tools you need to properly test and isolate this, but one thing you can do is get an analyser plugin that will show you more noise so you can see what's really down there. Pro Q isn't really the tool for the job. Voxengo Span is free and usable in this scenario. Get a good look at the whole noise floor, run the unit at 96kHz. Test it with nothing connected to the interface like the other dude said, and if you're using a laptop, try running off battery while you do it. With modern systems, you can get interference like that creeping in from so many different sources. Turn off or unplug as many nearby devices as you can do without, including lights. See if you can make that harmonic vanish.
BTW that's not a pole. A pole is a mathematical concept in filter design. What you have there is a harmonic. It may or may not be due to a resonance in some part of the system, but that kind of peak in the spectrum, with input that has no energy up there, it's not a resonance, unless it's an electrical one that is causing an oscillation, which it won't be.
