Thank you all!
Och tack till mina Svenska vänner!
Next up was doing some sidepanels at the metalshop.
It was easier and cheaper than a thought doing lasercut panels from the cad drawing.
The original Neve panels were made 3.2mm alu but could only find 3mm these days so went with that.
Not sure why Neve used so many inch related measures in their production, Ian do you know?
The first thing i had to do though was to build a new stand for the desk that would incorporate the new bucket.
Luckily i have a friend who owns a 8014 so i could study that and make up a drawing so it would look more or less the same.
These early desks and the 8014 uses a stand where the whole frame sits in it like a cradle.
Not the best design in my opinion since you can create sag in the middle from the wheight, so the frame have to be sturdy.
It is also hard to get the cradle leveled when you weld it, something i would notice a bit further on....
But there are no other options for this type of frame so i went ahead with the original design.
Next up was to remove the original sidepanel and dryfitting one of my new ones.
Looks good!
Then i used the original panel as a template and drilled out all the holes.
I carefully tapped and countersunk all the holes in the right places, there are so many holes that need to be done so it is very easy to tap or countersink the wrong one (yes, i did at least one of them wrong!).
This was insane work and i did it all by hand.
If i ever do something similar again in the future i will draw in all the holes in the cad drawing from the start.
That would give me even better tolerances for the holes, it is a bit tricky to do it all by hand.
Here are my three panels ready to be assembled!
What i came to realize is that the original desks actually uses six different panels in the desk that need to be drilled and countersunk differently.
There are the two outer panels on each side and then the two panels between each bucket which are all different.
For this build i opted to remove the original panel to the left in the desk and replace it with a new one.
This was so i could more easily attach the new bucket into a new panel and get a better fit.
