Hello!
I have a small tube amp, about 3 watts, that uses a Hammond PT269EX transformer (http://www.hammondmfg.com/pdf/EDB269EX.pdf). I'm thinking about replacing the Hammond an external wall wart that supplies 12VAC 3A to a 230V:9V transformer wired backwards. The B+ of the amp is 250V, so it may take a bit of play with filtering to get right.
I have only read a couple of posts about using transformers backwards like this. The set up will be about the same price as the Hammond transformer when using a wall wart and an antek torroidal transformer. I have a question of safety. One of my biggest fears is to plug my guitar in and go up in smoke. Is using an external AC adapter on the mains and stepping it up inside the enclosure safer if things go wrong than bringing mains power into the enclosure, closer to the guitar strings, or is that just wishful thinking?
