nhaudio
any idea on how to do it diy?
cheers nick
from www.rupertneve.com
"Two-channel ?True Tape? Emulation. An actual tape drive circuit is used to drive a tiny magnetic circuit and fed to a replay loop and actual replay preamp. ?Record? and ?Replay? levels are counter-ganged to keep overall gain approximately constant that only varies, as a tape would, with saturation level. The frequency response is tailored to that of an actual tape recorder. The result is a remarkable simulation of true tape sound, providing the nostalgic rounding and compression that offsets the harshness of poor digital recorders. Use with care! The dynamic range of a tape recorder was a lot less than that of the high resolution Portico Line circuit in which it is nesting!"
cheers nick
