sr1200
Any thoughts on the bar graph frying things?
sr1200 said:Any thoughts on the bar graph frying things?
Songguy said:Hey mike,
Sidechain xlr wiring question.
xlr: which pin goes to Send, which pin goes to RTN.
C
As far as I can tell, its hooked up exactly like my working unit1) Is it wired correctly?
its good2) Is the LM3916 on the control board in the correct orientation?
I will try this once i get home. I should note that with me pulling the thing in and out of the case, the 150ohm TO looking resistor near the bargraph disintegrated (literally crumbled and the leads came out of the black part with almost NO force. (ive had legs fall off regular resistors, but nothin like that lol) I ordered a new one and am waiting for it to come (hopefully today)Otherwise, disconnect and check if you have any DC voltage on the center pin of the bargraph connector on the main board (with a test tone signal present of course.) Level of DC will vary depending on how loud of a test signal you're sending to the unit.
If you do have a signal, your problem is on the control board, if you don't, then the problem lies somewhere in the VU Driver Circuit area.
Confirm, JMP6 and/or JMP9 isn't mistakenly populated and all +12V, +15V, -12V, -15V supply voltages are operating.sr1200 said:...the first point i tested was RW and R0... the working one i have almost nothing like 6mv (and i have a crappy meter) the non working one i have like -14V (something is a miss right here) The LW and L0 are the same on both units. (cap replacement time i guess) any thoughts on this?
You might have blown C32 again, if you didn't fix this -14VDC issue before repopulating this cap.sr1200 said:I did have a blown cap (one of the 100uf's) replaced it but it didnt help.
Seems right for a THAT2180. You never told us, what VCAs you are using.I just noticed on my working unit that jmp1 and 4 arent populated (unless i did it on the bottom of the board which would be weird)
Using the kit from Ptown. (so yes THAT chips)[/quote]sr1200] [quote author=Harpo said:You might have blown C32 again, if you didn't fix this -14VDC issue before repopulating this cap.sr1200 said:I did have a blown cap (one of the 100uf's) replaced it but it didnt help.
