minor_glitch
Thanks Ptownkid. Go figure, I work about 10 minutes down the road from Sayal and I've never bothered to check them out.
snipsnip said:reversing polrity on things tends to make them explode.
you should know this from watching science fiction alone!
buildafriend said:Hey I don't see anything on the BOM for the DBX unit/units. How many are in the project? I might just be missing it because I am uncertain what to look for.
http://dl.dropbox.com/u/4740474/SB4000_Production/SB4000_REV4_Part_Numbers.pdf
...and for DBX unit/units, make sure you know what type of modular VCA you're asking for. Looking at some threads, you seem to be looking for the 'gold can' VCAs DBX202C, coming with different parameters than the 'black can' VCAs DBX202. There are some other VCAs for this type of footprint around, namely the 'silver can' DBX2001, the 'blue can' THAT2002N, THAT2002R, THAT2002T or the 'open frame' DBX202X, DBX202XL, THAT202R, THAT202XT, THAT202XTC or THAT2002T1, all with more or less differing parameters for control voltage law, supply, max.i/o-current, ...ruckus328 said:buildafriend said:Hey I don't see anything on the BOM for the DBX unit/units. How many are in the project? I might just be missing it because I am uncertain what to look for.
Because DBX202's are a mod, standard design uses THAT2180 or THAT2181's and BOM reflects this. If you're using 202's you need 2 of them for the audio VCA's. You'll still need 2 THAT2180's or 2181's for the sidechain (doesn't matter which one or what grade)
minor_glitch said:How critical is it to clean the board after soldering? I'm using Kester 245.
It claims to be 'no clean' but should I still try to clean it up a bit?
Oh I see. It won't hurt to have both units so I can find the better of the two. Do you have to change any surrounding resistors or caps to use either the THAT or DBX?ruckus328 said:buildafriend said:Hey I don't see anything on the BOM for the DBX unit/units. How many are in the project? I might just be missing it because I am uncertain what to look for.
buildafriend said:Oh I see. It won't hurt to have both units so I can find the better of the two.
buildafriend said:Do you have to change any surrounding resistors or caps to use either the THAT or DBX?
ripgtr said:Hookup wire.
Any minimum I should be looking at for the gauge of the hook up wire between the boards and say the power board or the switches? I have a bunch of #26 in different colors. Should I be using something bigger? Yes, I know about the 14 gauge for the star ground but I am looking at all the other wires.
So, I see the power supply as - Transformers 36.0V CT @ 0.69A 18V - and looking on the web, see #26 up to 2.2 amps - http://www.powerstream.com/Wire_Size.htm - so I am guessing I am good, but I would rather not guess.
Use what I got, or go shopping?
