ruckus328
With no compression and Gain at 0, input and output should be the same. If not you have some other issue going on.
ruckus328 said:The "u" is the decimal place (in microfarads). So u1 would be .1uF, u01 would be .01uF, etc.
The J I'm not sure about, don't know if that's a standard or dictated by that particular manufacturer (probably)
250 I would assume means 250V, but doesn't really matter as anything over 50V is plenty fine.
You only cut those if you're adding the crush & blend circuit to your unit. If not, just leave it alone.buildafriend said:Whats with the little stars on the 200Ohm R?
What is meant by CnB C'mon cut it? Why should I or should I not cut the trace?
sea_man said:Hi !
I bought the complete kit and i'm welding the electrolytic caps, but i have a question..
in the SB4000_REV4_Part_Numbers.pdf appears this:
8* CAP, 100uF, 35V, 20%, ALUMINUM ELECTROLYTIC, LOW ESR
18* CAP, 22uF, 35V, 20%, ALUMINUM ELECTROLYTIC, LOW
But in the capacitor bag have only 17* CAP, 22uF, 50V, ALUMINUM ELECTROLYTIC and 8* CAP, 100uF, 50V, ALUMINUM ELECTROLYTIC
Is safe weld this of 50v instead the 35v ? and is the 17* 22uf caps sufficient ?
Thanks !
