sheadstedford
Hahaaa poor bastard
minor_glitch said:I think I'm just about ready to power up my unit and start testing/calibrating, but I want to make sure I've wired up the power supply properly. Ideally, I want to avoid turning my home into a crater when I power it up!
I'm using the VPT36-690 transformer so the primaries are blue and gray, and violet and brown. The secondaries are black and red, and orange and yellow.
For the primary I tied the blue and violet, attached them to the bottom pin of the power switch, then ran a wire from the center pin of the switch to the pin after the fuse on the iec inlet. The gray and brown are tied together to the other pin of the iec (the ground pin obviously going to the star ground).
Would it make any difference if I had done it the opposite way with gry/brn to the switch instead of blu/vio?
For the secondary, I have the wires hooked up black, red, orange, yellow. Black being closest to the bridge rectifier. I'm fairly confident those are fine.
Now for the stupid question. If I remember electronics class correctly from many years ago, even though the tranny is wired for 115V, it's perfectly fine to use with my home's 120V right?
sr1200 said:Im still at a loss on my second unit. im beginning to think that perhaps i have a bad relay. What pins can i jump on the compress in/out relays to test my theory.
sr1200 said:Ive run out of room on the VU meter calibration. Needs to go a bit lower, anything over a steady -9db is causing the meter to PIN to the top.
