ruckus328 said:
Strange, first time hearing an issue like this. There is an error somewhere, but this has nothing to do wih the 47K resistor. Could be alot of things, but my first suspect would be dodgy +/-12V control voltage. Check and make sure you have proper +/-12V on the main board. Check voltage on the pins of your threshold pot on the control board (you should have +12V on the CCW pin and -12V on the CW pin), to make sure you have propper +/-12V on the control board. Buzz out your ribbon cable and make sure you have continuity to rule out a potential bad connection.
Also, run a mono signal just on the left channel and see if you still have this problem. Then repeat for the right channel. This will help narrow down if it is an issue in one of the channel's ratio/feedback networks or if it is happening after the summing point.
Hi ruckus328, if I can trouble you with a question or two
First, Happy Hollidays!!!
Secondly,
I have not fixed my SD4000 yet (I originally posted my issue on this thread page 30), and can't figure out what's wrong.
It works at low thresholds but when a medium to strong transient comes along the compressor pegs wildly and the audio cuts out momentarily. Non-compressed audio quality is awesome, and the unit works and compresses ok at <4dB of compression in the 2:1 mode. The attack and release controls seem to be doing what they're supposed to...
Also, if I slow the attack mode down to 30ms (lowering the transient compression) it lessons the amount of the problem, but it still messed up and freaks out at high levels of compression...
To explain the problem, if a solo piano is playing through the unit it sounds good till it hits a hard chord then the unit slams un-proportionately hard and audio cuts out for a split second.
Question ??? Does the threshold pot move the Compression Meter with the compressor in bypass mode? Mine does, it seems strange to me... Maybe that's a hint to where the problem is...
Also, the same error happens with the compressor in both mono or stereo internal sidechain mode. The ext sidechain is not connected...
So I followed your advice and tried running a mono signal, through both the left and right inputs. There is no difference, in both channels I get the same error??
Also, I checked voltages. If you're looking at the unit the threshold knob's left wiper measures +11.85V and the right measures -12.11V.
I get similar voltages at the power supply. I did install a variable resistor on the power supply vr19 because I couldn't get the voltage right with the supplied fixed resistor...
I also double checked all of the solder joints, because on my other projects that always seemed to fix any issues.
I flip flopped the vcas around too, just for grins
I checked each pin of the ribbon connector and it checks out ok, and I reversed the ribbon cable and everything went berzerk, so I think the ribbon's ok ??
If it was bad vca's wouldn't I notice a big difference between the left and right channel, they're pretty consistent. It seems like there is a problem with the detector circuit??
Sorry for the long email, but if you have any ideas or testing points I'd greatly appreciate it!
bless,
Greg
