Harpo said:
sr1200 said:So I reversed the phase on the output XLR's since I dont ever plan to have that unit in the chain without being engaged.
sr1200 said:ONe of the boxes i did the "fix" by crossing the resistors on board. The other box (where i didnt read that post first while building it) i just swapped the +/- on the pins on the XLR out.
sr1200 said:Just a note, the fix i posted isnt really a fix for anyone in the future... all it does is put the unit back in phase when it ISNT bypassed, when you bypass it will be out of phase again, (theres a little trick to use the ext side chain w. nothing plugged in to bypass instead of the big red buttons) just wanted to throw that out there. I never have the unit in the chain when im not using it anyway so for me its not a biggie, i just un-patch the beast.
buildafriend said:Blue and purple are together
Gray and brown are together
L hits the common tab on the switch
Other pin on the switch go's to the fuse
other side of the fuse connects to blue and purple
Brown and gray go to N on the IEC
ground.. ground.
wave said:The BOM from page 1 lists 2 16 pin DIP sockets for SK17, SK18.
I'm not finding a location for these on any of the boards.
Am I supposed to chop them in half and get 4 - 8 pin SIP sockets?
(It seems like chopped , they could populate the sockets for my THAT VCAs)
The 'L' lug is the terminal below the 'N' lug from your fused IEC inlet.drjoe said:Another transformer wiring question!
I'm wiring for 115VAC with a fused IEC. I'm a little confused about the wiring.
This is the most straight forward explanation I found in the topic:
ground.. ground.
But since my IEC is fused, I'm not sure which side of the fuse to connect the blue / purple.
Can someone verify that my diagram is correct so far and help me determine the other two connections?
wave said:drjoe,
Thanks for the input. I chopped mine.
It seems like you and I sourced the parts ourselves. I was wondering, did you get STMicro regulators (mouser # 511-L7912ACV)?
I did and then I read this support thread. Seems people were having problems with the 7912 VOLTAGE REGULATOR made by STMicro.
buildafriend said:You should just use my PSU wiring that is gone over earlier in this thread.
Harpo said:The 'L' lug is the terminal below the 'N' lug from your fused IEC inlet.
Nothing wrong with using rivets to fix your IEC inlet, as long as you make sure the nail end doesn't rattle lose and drops out of the rivets hole into your case and -from murphy's law- lands on a spot where it causes the greatest harm. (Same chances are for nuts getting lose from a bolt, so a drop of paint should help to avoid this.)
The quoted colour coding from buildafriend are for his transformer. As these codings are not standarized, yours may be different, so look at the label printed on your transformer or look at the datasheet of your transformer to be sure. For 115VAC mains you connect your transformers dual primary windings in parallel by joining both in-phase winding ends (most often indicated by a dot) and both out-of-phase winding ends. Your fused IEC 'L' lug goes to the switch, other pole of your switch connects to one end (order doesn't matter) of your paralleled transformers primary windings, transformers other primary winding end connects to 'N' of your IEC inlet. IEC safety ground connects to your case ground by a solid connection. Scrap off the case painting in this spot to ensure conduction.
In buildafriends description from pg.34 of this thread he also mixed up the order of fuse and switch, but with your fused IEC inlet this will be irrelevant for you.
