So, im nearly there
BUT alas.. I got the right voltages on the PSU, but when i connect the main pcb: SMOKE from the 10R resistor at R182, and the powerrails read wrong values.. If i disconnect the main-pcb - everthing is fine, and perfect values on the powerrails..
I have checked the connection between the PSU and mainboard, and its wired ok (+15V goes to +15V, 0 to 0 etc.). I also cant seem to find any wrong wired components, but clearly theres an error somewhere!
Any thoughts would be appreciated..
A hi-res pic. of the unit:
(VR18-VR19 are wired on the other side of the psu-pcb.. They are not missing..
EDIT:
I had turned the three TL074 the wrong way
Now the 12V rails read ok, but im only getting 3V on the 15V rails..
EDIT:
