Just wanted to drop a line... I used one of mine last night to smack the taste out of some drum room mics... damn this thing is sweet!!! Usually reserve the other for mix bus duties, but haven't gotten to that point yet... still tracking!
mica said:Im nearly finished with mine based 100% on the BOM, bought from Mouser..
A couple of newbie questions:
1. The Jumpers 1-6 in the R+L VCA area.. should I "jump" those or some of them? Cant seem to find it in the guide.
2. R111, when should I use that? I have the VU from Hairball Audio: (http://hairballaudio.com/shop/product_info.php?cPath=25&products_id=61)
3. The jumper on the control board next to the bargraph - JMP7.. Should I "jump" that?
4. On the back of the main PCB, it says for CnB: CUT ME! Im not shure about CnB.. When should they be cut?
5. J19 3pin (close to center of mail pcb)? What is that for?
/Michael
tom f said:Hello,
while building the SB 4000 I have one question.
Which VU- meter do you have installed and where did you get it
(Im in Germany) ?
Thanks a lot
Tom
mica said:Great!
I ran into another issue..
My trafo has 4 colored wires, and 2 yellow: 2x18V (gn-rt / bn-bl) - unlike the ones i have seen in the documentation, and in this forum.
My powerswitch is mouted: I on top, and O in bottom.
How shuld i connect the power to the powerswitch and to the trafo? (We have 230V here in Denmark)
wave said:mica said:Great!
Can you send me a link to the datasheet for the trafo?
Dave
band_master said:so i discovered that the excel version of the bom has the wrong mouser part number 3266W-1-102LF for VR5,VR7,VR8, and VR10.
it is a 1K trimmer instead of a 10K...i think the actual mouser part number should be 652-3266W-1-103LF? we'll see if that works.
