Blackdawg said:
1) ...R76, R96 on the outside of the main board are labeled 680K.
resistor value is depending on type of VCA used. 680K is ment for a THAT2181A. (have a look at the schematic to get corresponding parts values for some different types of VCAs. Corresponding values for your specific quad-VCA are listed on the Quad-VCA-BOM).
...But they are supposed to be changed to 5.1k from 15k. Is that still correct?
Neither this is correct nor is the BOM saying so. (that would be true for R38 and R49). Please read it again and sort your numbers.
Why does the board say 680k?
With limited pcb real estate you have to decide what information to place on a silkscreen. The table on schematic
only lists 8 different types of VCAs. There are some more, again requiring different values for best performance.
Do I just use the 5.1k resistors that don't get used where the normal VCAs go? as in R105 and r148?
R148 isn't 5.1K but 68K and part of the ratio network. Be more exact with your numbers. Sure you can use a correct value part in a different spot when you have spares... (Bias current setting value of 5.1K is ment for THAT218x VCAs in this spot and is depending on supply voltage and type of VCA used. FI a similar NEC or DBX part might require a different value).
2) Says 10k pots would be better but the included 50k will work. Doesn't matter though right so long as I get them to 5K as iIunderstand it correct?
5K would be the trimmers initial parts value that
might need further adjustment for desired performance. A 50K part has a reduced rotation angle for dialing in the target value, but should work.
