[silent:arts]
Why? You might first let it pass audio and hear if you like it?sonolink said:I was wondering if it's possible to add an output pot. Any ideas how to do that best?
synthiaks said:This is a multi purpose amp so it could be used for stuff like line amplification or buffering. The +/- on the front is there to compensate for the differences in the gain when using more amps. The Resistors on the back wont be perfectly matched so the amps will not have the exact same gain.
synthiaks said:The output pot would be an Attenuation potentiometer working as a resistor tied to ground i guess. You could the run the amp high and turn the output down. But you could do that in your DAW also.
synthiaks said:Or do you want a Gain Potentiometer when you say "Output"?
synthiaks said:And the maximum gain is 43dB and it can't be pushed anywhere higher than that.
moamps said:I have uploaded the correct schematic for V372D.
sonolink said:Synthiaks, thanks a lot for your input
sonolink said:Well that's more or less what I meant by "calibration" earlier in the thread. Sorry for my english
I'll keep in mind that it's then important to have that pot represented somewhere on the enclosure.
sonolink said:That's exactly what I meant. Regarding doing that in my DAW, I guess I could by i.e.: inserting a Trimmer plugin in the input of a channel in Pro Tools. But I'm in doubt here: don't you think that the signal should be attenuated to a healthy level before being converted? Just as an example, If I have a Kick or a very loud voice and I crank the gain up until it sounds VERY colorated and nice I will be saturating the preamp output. So far so good, but what if the signal also saturates the sound card input? It won't be levelled until it reaches Pro Tools right? Wouldn't it be better to level the signal just before entering the sound card? Or is it the same really?
sonolink said:No. I understand that I already have a Gain pot and to have another one to get more dBs I would need another stage. In any case I meant an output attenuator
sonolink said:Absolutely, and it probably is plenty anyway
synthiaks said:It all depends on what sound card you have and how the input is treated. With no proper pad or input attenuation it could be too hot no matter what you do, but then you should think about buying some real recording gear!
synthiaks said:Put two 600ohm resistors in series with a dual 2k pot wired as a variable resistor and use it for the RGKs With the calibration potentiometers you then make sure the two channels are equal in gain for stereo use. or you use one Dual and one singel with a LINK switch for stereo use.
sonolink said:So no Output pot is useful right?
[silent:arts] said:However, before thinking about all this (possible) options I first would make sure the units are working, and hear how they sound
[silent:arts] said:With 20% tollerance I wouldn't call a dual pot well calibrated ...
If you need stereo matching rotary switch are more accurate.
