thecr4ne
I've got two schoeps CMT-56's I'll be working on. This thread is to document and share the process. Here's a quick rundown:
-Both use P48 phantom power.
-One has a non-standard XLR connector, I suspect it was originally a tuchel connector and was changed.
-The other is labelled CMT-54, which I think means it originally had a cardioid capsule, but now has the multi-pattern capsule
-Internally they appear the same, with the following exceptions:
--One capacitor is different between the two (same value, different style)
--Transformer secondaries appear to be jumpered differently. Possibly for different output impedances.
--A few wired connections to the XLR connections vary slightly as well. One has some connections the other doesn't.
When I get a chance, I'll get photos posted and try to dig into the variations a bit more to see if they're significant. Hope to also do some rudimentary sweeps with REW.
