Making two Vari-Mu compressors behave perfectly in sync is almost impossible, unless you have 100's of 6386's to select 8 perfectly paired.
It seems the internal push pull balancing is not too hard to achieve, thanks to the 4 paralleled triodes on each side. So perhaps not so much of an issue for a 660.
However it maybe difficult to have two channels of the 670 match in level at the same time.
On the Unfairchild they added a trim control to fine tune the gain, altering the bias of the 6386 tubes.
One of the videos from the series I mentioned above is showing an interesting test, trying to make a set that is matched well enough out of 8x random JJ 6386 . For sure the gain trim control was useful to achieve level balance between the two channels which would have likely been impossible with just 8x tubes available.
I guess unmatched bias between the two channels would have the consequence of a different distortion profile, but I reckon that would be more difficult to hear than a level imbalance that messes up the stereo image.
Overall I think they made an intelligent choice, because it doesn't force them as the manufacturer or an end user in need of s retube having to buy so many 6386 - for which JJ has a monopoly and charging a fortune.
Which goes against the very essence of a 660. The power amp used to drive the side-chain is a distinctive point.
If you don't do that, you'd better build a 436.
I have the feeling they have chosen that route mainly to save costs or some kind of manufacturing compromise, but perhaps in practice the end result is not that different from the original ?
Basically they changed the tube in the 2nd gain stage (ECC81 instead of 12BH7) and the output stage (ECC99 dual triode instead of 2x 6973)
Personally I think even with the different control amp configuration it would be a bit unfair to compare it to a 436, having said that I would certainly be interested to know what you think the shortcomings of the alternative control amp configuration could be from a technical standpoint.
