pucho812
It’s purely a sonic reason here.Since I never had the opportunity to do the comparison, I won't argue. I'm just trying to understand the possible objective explanation.
I understand that, but there must be a technical reason for it.It’s purely a sonic reason here.
well Geoff Emrick would tell me more current to move the music around on a 660 then a 670.I understand that, but there must be a technical reason for it.
By the way, the Fairchild name was purchased and they are making equipment again. So unless that is you, you may rethink that last statementThis is a real good thread. I have built now about 14 670 clones , or at least my version. I do use a solid state side chain amp for several reasons. Many of the reasons are mentioned, lighter weight more headroom , but reliability and stability are the big reasons. While my audio spect meet or exceed the original specs, recently I have built 2 units with switching power supplies and doing extensive testing. Again, much lighter weight, less heat, and the Nigel to noise specs are amazingly good. Much better. Oh and buy the way, I am the only person that has an actual license to use the name Fairchild.
Happy building everyone!
Why not substitute for a bunch of 6ba6's with cathode balance pots to set the bias between the two sides. Get them reasonably closely matched and then dial them in by hand. I'm talking about a 660 hereOverall I think they made an intelligent choice, because it doesn't force them as the manufacturer or an end user in need of s retube having to buy so many 6386 - for which JJ has a monopoly and charging a fortune.
that's why I put fare child on my recreations.Just for grins, I checked the USA Patents and Trademarks website:
https://tsdr.uspto.gov/#caseNumber=...TION&caseType=DEFAULT&searchType=statusSearch
Both trademarks owned by these folks:
Western Electric Export Corporation (CORPORATION; GEORGIA, USA)
Which are these folks:
https://www.westernelectric.com/
Avid also owns a trademark for "Computer software for audio production."
Those were the only active, audio-related trademarks I found.
Just FWIW!
Bri
35K and they use Alpha potentiometers, or even worse fake Tocos potentiometers, the cheapest rotary switches and tube sockets you can get.https://www.sweetwater.com/store/detail/670Comp--fairchild-670-2-channel-tube-limiter-compressor
This is the new 670, I believe the name is owned by Telefunken, at least they were cited at the beginning of the reissue process.
I think that just having one trim pot trims all stages, at least to some extent. This obviously depends on the particular stage you are measuring to set the trimmer up.I am not sure you need a trimpot for each pair of tubes like on the Stamchild, DaveP has built a 660 with 6BA6 and it seemed to work well with just the stock balancing circuit.
This is the video I was talking about
Ok what about a 436 sidechain on a 660 signal amp? Skip the complicated power supply and control amp and just do 8 6BA6s.Which goes against the very essence of a 660. The power amp used to drive the side-chain is a distinctive point.
If you don't do that, you'd better build a 436.
As long you don't try to pass it for a Fairchild, it's fine by me. You could even replace the 6386's with transistors and use a chip for side-chain, as long as the result suits you, you're free.Ok what about a 436 sidechain on a 660 signal amp? Skip the complicated power supply and control amp and just do 8 6BA6s.
It's not a Fairchild so not what I'm looking for, but maybe for someone who wants a 436 without the 436 distortion and a smoother character.
I made an experimental gain stage with 4x 6BA6 and a pair of edcor transformers. I was controlling the gain with a bench psu. It seemed to work ok. I never got round to trying aproper side chain circuit with it.Ok what about a 436 sidechain on a 660 signal amp? Skip the complicated power supply and control amp and just do 8 6BA6s.
