[quote author="daArry"]I just sent of my dual 1176 front design n panels of to schaeffer too
PDF here: http://notapplicable.co.uk/audiolab/1176/FrontDesign%20[1176.pdf
[/quote]
Hi daArry.
I just looked at your panel...
Its your design... but i would prefer the ratio settings like "4:1... and not 1:4...) or have you changed the board layout so that the compressor don't works as a compressor? :roll: In this case I would change the word "limiter" :wink:
Hmm... and I just looked Jakobs site... and the panel layout says the same... 1:4... and the proto unit is also labeled with 1:4 and the adjusting infos also says 1:4.... and i looked at my first diy urei... and it also says 1:4 :green: :green: :green:
Whats that power switch? Are the screws really bigger than the other screws for "link dual" etc.. ? Because the holes are more than close to the switch itselfs.
And if you want to use vu meters without a bezel you should choose another radius for the meter cutout.. otherwise you'll see round holes in the edges of the meter.
The ratio lettering is smaller than the meter lettering... i would only use two sizes... and the attack and release... slow and fast is another size as the "5" or not?
If you don't want to see screws on the frontpanel you could use threaded bolts from the backside... you have to make a new panel layout (which is actually for only ONE panel) and send it also to schaeffer.
(just some ideas)
Regards,
Frank.
