Svart
So, a couple of grand poorer, I opened my new Alpha link AX pretty much as soon as I took it from fedex's hands.
I should have pictures in a few days but I'll describe what I see for now.
jrc njm4565(.46$ each) opamps(buffering duties) I haven't traced them out to see what configuration they are in yet though.
highlights(lowlights?) 4v/us slew, drives 400R loads@ 20vp-p, 90db CMR, 1.2uvrms voltage noise
AK4620BV (~4-8$ each) 24bit 216khz stereo codec. Pretty much the normal dual bit/switched cap stuff here.
analog I/O is AC coupled through SMD electrolytic capacitors, unknown brand, 10uf 35v. NO servos here.....
Analog board says SSL, ADAT/Digital board says SYDEC.
simple off the shelf SMPS bolted in the box.
Lm7805 power for AD/DA..
19"x2Ux8" aluminum box, about 80% empty space... no fans, etc.
Everything is SMD.
I'm still waiting on the Mixpander card from Oxford to be able to use the setup so I still don't know how it sounds or compares to my MX2424.
Now comparing the MX2424:
has opa2604 in every opamp duty. higher performing AD/DA ICs, MUCH larger inductors and caps on analog boards, LDO Vregs for AD/DA, MUSE and Cerafine caps for I/O decoupling.
Should I be disappointed with SSL for seemingly going seriously cheap here? I'll wait to pass judgement on the sound but I serious think they could have invested more money into the boxes..
Anyone have any of the other SSL boxes that can take a look and see? I'm wondering if the higher line of MADI boxes have better analog I/O.
How does this compare to other company's boxes (apogee, digi, etc..)?
Everything is SMD.
