i can do it
will pm email
cj
btw, i just finished a/b ing the hickboy against a proco di.
the proco is just a transformer with a ground lift and tone cap which is useless so i threw it out.
also the ground is almost always kept in the gronded position so i threw that out and used it for a pwr switch for the hickboy, which is an active di.
simple fet design kind of like Bo Hansens. UTC A-39 output transformer on the active box.
anyway, long story short, the hickboy sounds a lot better than i thought against the simple transformer di.
more tube like and has character, where as the passive di sounds thin and low level, with no mids or personality, but a very clean signal, whereas with the hickboy, you pay the price of much better tone with a touch of distortion if you push the bottom end, but no big deal.
i threw in a 0.0082 uf cap across the 10k input resistor on the hickboy and it really brought out the tone on my tele deluxe, so i put it on a switch for a tone tweak.
used 8 sanyo nicads with a 1/4 inch jack in the back via a 39 ohm resistor for charging the battery pack wich sjould last 5 or 600 hours on a single charge.
led draws 300 microamps as a pwr indicator.
both di's racked in the same 1u box and a totally cool project.
thanks to Bill Y for all the info!
