You never had a shorted connection? Particularly if there's a patchbay involved, you can chase your tail for hours wondering why you have reduced level and distortion.How often do we encounter gear with unbalanced inputs? Even the cheapest home recording equipment nowadays has balanced inputs. As far as I know pro audio equipment has always had balanced inputs. Only gear with unbalanced inputs I have used have been tape recorders for home/semi pro use.
If left floating you loose 6 dB and you need to modify your wiring, which always happen when you're busy and you lift the wrong leg...Distortion if one of the output pins is grounded and no problem at all if left floating.
Building a clone of an existing piece will teach you little, when building something with limited resources will tell you a lot; the road is twisted, though...I also did a 33609 pcb but before drilling the huge single sided board I realized It was to expensive to build... That s why I started a simplified one, with components I just own
Yes, the Yamaha GC2020 compressor, for example.There's still plenty of gear and consoles that use unbalanced send/inserts.
great! thank youFor a much simpler implementation, you may want to look at ground-sensing impedance-balanced output.
Check Balanced output w/ MC33079
post #14
The only drawback is you can't claim +26dBu output.
