Simple DiodeBridge Compressor
Hi Xmission
Basically the schem is that...
I left the project opened cause still in progress...
I wrote all the updates....
Hope to finish soon and upload what can be called a final version
Best
Richi
This is a blend control, i m running it on a mono RM57 limiter, and works fine....didn t noticed problems
I will add thinking about a stereo version with stepped pot for blending, since understand that it s very difficult having matched dual pot
Any suggestions to improve the idea?
Thanks for your attention
Best
  • BlendEasyAmp.pdf
    39.1 KB
this is the comparison with the add of the extra buffer by Dogears
1u for timing cap
fast att, slow rel - max Thr and Ratio
    122.8 KB
sorry for the wavefroms, different signals, the upper one was double the freq...
    110.3 KB
    57 KB
Google "OpAmps in Line-Driver and Receiver Circuits" by Walter Jung, then this
https://www.ranecommercial.com/kb_article.php?article=2112See in the attachment how Soundcraft did it for about 20 years.
Today, almost everybody uses dedicated chips from THAT, SSM or TI.
Thanks for the info....
The attached one is the quasi floating from small signal audio design
I know modern ic are better and easy to plug.... But still have few ne5532 and tl072 to use....
Best
Richi
I read Rane knowledge base... Very interesting... Finally I m starting to understand cross coupled config...
Thanks for you support!
Best
Richi
another balanced out attempt
now i get less offset in the upper range
and with R8 obtained less ripple for 1k harmonics
that s the maximum i can verify!
thanks for you attention
cheers
    161.5 KB
Do you really want that? You can't connect that to an unbalanced input.
How often do we encounter gear with unbalanced inputs? Even the cheapest home recording equipment nowadays has balanced inputs. As far as I know pro audio equipment has always had balanced inputs. Only gear with unbalanced inputs I have used have been tape recorders for home/semi pro use.
I m running unbalanced send and return on a 80s console in my pseudo lab.. Which problem I could get?
Overloading the return?
Or shorting the cold to ground can cancel the signal?
Distortion if one of the output pins is grounded and no problem at all if left floating.
