totoxraymond
Hi everyone,
I'm starting a new project to help my recording workflow here in my small studio.
Let me explain: Right now, I use Nuendo along with an RME FF800 to record music. All is good but i always find the 'low latency monitoring' a bit quirky.
Obviously i disables all the inserts of the recorded tracks so the musician can here himself without too much delay. But then when you do some overdubs on an almost finished mix with lots of compression (i mostly record punk rock, it might get loud), it's hard to judge the performance live.
So my idea was to ditch the low latency thing and setup an analog path for the musician's feedback. Ideally i'd like an analog mixer, but this is a small studio allready packed with stuff (and recording music is not the main use of the studio).
Then i got into this idea: What i really need is to be able to blend one or two mics (ie a guitar and a vocal mic) with the 'Cue' feeds from Nuendo (I have four different Cue feeds setup right now)
So maybe I could make a small mixer in a small 1RU chassis and that would do the trick.
I made a crude block diagram to describe the signal path, see attached.
I will add a Headphone amplifier to the mixer, so i can monitor what's been sent to the musician from the control room.
So, next step will be to design the summing board.
Thomas
Thomas
