SMT rework
Andy Peters
Sunny Tucson
So the two engineers working on a board (one being me) fscked up the power connections for the configuration logic section of an Altera FPGA in a BGA. A ball on the package was connected to the wrong power supply rail, and as such the FPGA wouldn't configure.
The balls all have the little dog-bone routing escapes. The power pins connect to the appropriate plane through a via from the dog bone.
It was a 10-mil via with a 20-mil pad. Our ace technician drilled out the barrel of the via that connected the trace to the plane, leaving most of the via pad intact. He then put a dab of conductive epoxy into the hole, and stuck a thin wire in, and let it cure.  This made the electrical connection between the wire and the via pad. After cure, he tacked the other end of the wire to a pad of the correct power rail.
I powered it up with my JTAG programmer attached, and voila -- the part configured right away. And I was also able to program the configuration EEPROM. And now I can get on with debugging the design ...
So all of you who are complaining that "SMT REWORK IS HARD, WHINE WHINE WOE IS ME THRU-HOLE OR BUST" can just go sit in the corner and be quiet.
-a
Are you saying that wasn't hard?  ;D
You guys need to each buy that tech a beer, or several.
I had enough pain dealing with layout mistakes in inner layers of 4 layer PCB...  similar remedy, drill out the via (if it isn't hidden) and jumper connections on top/bottom, but layout matters around switching PS, and codecs, so still need to go for another cut to prove the design.
Luxury! When I were a lad we had to do Focussed Ion Beam milling and metal vapour deposition on ASIC prototypes to prove a metal-layers only bug fix using a couple of spare cells.
