[quote author="mikka"]
..... but the turd is polishing me.[/quote]
what a beautiful image :?
Regarding replacements for the SSM2017. Those chips are certainly worth a try, but on the other hand they're not available everywhere. I think it makes more sense to look at the other parts of the circuit I described before you consider the SSM.
The BB and That chips perform superior, but I doubt they will make a noticeable improvement in the exact same circuit, which was designed for a SSM2017. You see, pin compatible does not mean 1:1 interchangeable. They will work, but the manufactures performance claims relate to the circuits in the datasheet. I recently exchanged emails with a guy from Greece (I think) who tried to modify an SPL Goldmike, which also uses the SSM2017. He put in an INA217 and couldn't hear any difference. So, if you're considering those upgrade chips, you may have to analyze the surrounding circuit and change stuff according to the BB/That datasheet circuits.
BTW: the That 1512 is meant for new designs and will require some changes in the circuit, the 1510 is designed as a direct replacement for the SSM chips.
